details? pics? links? where's the good stuff manpointsnorth wrote: ↑Tue Jan 10, 2023 8:54 am I finally just bit the bullet and ordered the fuel cell Ive wanted since I started.which in all my searching is the only cell that specificailly made to fit a in tank LS pump
Top Ramen
- Been Liked: 92 times
Re: Top Ramen
Re: Top Ramen
I wasn’t up to paying their price for the fuel line kit so incobbled my own together with Amazon parts
Re: Top Ramen
got a 4.0 xj rad on the way as well as looking at the diemensioms I think it will work
Re: Top Ramen
rear rad or will it fit up front ?pointsnorth wrote: ↑Wed Jan 11, 2023 10:25 am got a 4.0 xj rad on the way as well as looking at the diemensioms I think it will work
Re: Top Ramen
still going for a rear mount rad. but with me looking at chopping the frame rails to make more room. a front mount might be a possibility
Re: Top Ramen
I was looking at the an conversion fittings just not sure on how well they would hold up on a wheeling rig
Re: Top Ramen
I’ve got the xy rad here now as well as a 2007 Silverado 1500 here. Tonight’s shop night will determine what I decide to use.
The Silverado rad will work with the fans I have now I pretty sure anyways.
The xj rad will not
The xj rad will not
Re: Top Ramen
what do you mean? conversion for what ?pointsnorth wrote: ↑Wed Jan 11, 2023 1:22 pm I was looking at the an conversion fittings just not sure on how well they would hold up on a wheeling rig
if you can fit it i would do the chevy rad as im sure its bigger and will be easier to get at most parts stores if you need one when out of town ectpointsnorth wrote: ↑Wed Jan 11, 2023 1:25 pm I’ve got the xy rad here now as well as a 2007 Silverado 1500 here. Tonight’s shop night will determine what I decide to use.
The xj rad will not
Top Ramen
We got the rear axle truss drilled and welded up last night. Can’t upload pics where I’m at now.
I finished off the tcase installed the out put flanges, seals and sensors. I thinking for piece of mind I might notch the frame as the 4wd sensor is really close. I finally fixed the gacked threads on the front shift detent plug that I’ve put off forever
