- Has Liked: 158 times
- Been Liked: 92 times
its pretty close, looks like i can drill some new holes and the rear mounts will work. front will have to figure something outScott Cee AKA 2drx4 wrote: ↑Mon Nov 07, 2022 4:44 pm Sweet. Looks like it's more or less supposed to be there.
- Been Liked: 19 times
How much clearance do you have between the 271 and the frame web when it's clocked up like that?
can get my hand in there so enough roomarse_sidewards wrote: ↑Wed Nov 09, 2022 2:21 am How much clearance do you have between the 271 and the frame web when it's clocked up like that?
36" 80s frame, right?
I'm basically wondering if I can fit a 271 into a 32" frame without offsetting the trans so much that I have to start hammering firewall and tunnel.
i can measure this weekend but i wouldnt think it would fit. its really tall tcase as its rotated up now so flat on the bottom but taller then the frame rail. also really wide, like i might have to build a new trans crossmember as the angled mount from the top of the frame to the crossmember might be in the way of the drive shaft nowarse_sidewards wrote: ↑Wed Nov 09, 2022 8:48 am 36" 80s frame, right?
drilled some new holes in the cab and used some OBS ford body mounts and got the rear of the cab mounted, front is still sitting on wood. with the cab "mounted" i took some measurements and cut 14" out of the frame to make the short box i have fit
fish plate
nice and short, sitting at about 117 wheel base
fish plate
had to trim the rear of the box and its just sitting there for right now but wanted to get it on there and see how it lined up with the cab. its a "wrong" box so the body lines dont match but from what ive found for pictures i have it pretty close to matching the cab
with the box on i was wanting to get a real feel for it so finally got around to mounting my 39s up. picked up some Black Rhino beadlocks like a year ago, really liking the look of them
and damn that looks good
will have to do some fender trimming on the front for sure
- Has Liked: 85 times
its a little high in the back right now but i do have a 1" block i can pull out. its defiantly taller then i was hopping for but oh wellScoobienorth wrote: ↑Mon Nov 14, 2022 11:33 am That will look great finished up. Got a nice stance on it
Might come down a bit more as you bolt more parts on too eh.
Those beadlocks are sexy AF.
im sure it will drop a little but even then its going to be tall, im sort of ok with it as not going to be a hardcore rigScott Cee AKA 2drx4 wrote: ↑Mon Nov 14, 2022 2:42 pm Might come down a bit more as you bolt more parts on too eh.
- Been Liked: 49 times
been chasing rust and think ive cut out about 25% out
someone before me did some repair and it was pretty hack, not saying what im doing is much better as dont have the right tools and not cutting all the rust out.
even had the gf helping
not pretty but will keep our feet in and the bottom of the A pillar is solid-ish again
