Top Ramen
Re: Top Ramen
Transmission mount is finished proper. Tcase is bolted up for the final time. Black box bracket for the shifter is done and mounted
Re: Top Ramen
We also got Taylor’s canyon front end back together and sitting on four wheels. New spring packs having it sitting much lowered and the body roll should be more manageable
Re: Top Ramen
front tube work looks really good :smokin:
Re: Top Ramen
pointsnorth wrote: Thu Feb 16, 2023 9:59 am Image
It's a leaf spring SAS in the front?
Re: Top Ramen
Scott Cee AKA 2drx4 wrote: Thu Feb 16, 2023 5:58 pm
yes it is. Toyota axles locked front and rear. used a chevy 63 rear kit from trail gear. Tacoma length draglink
v8 swapped with a all aluminum 5.3 which is actually a lot lighter that the stock motor
Re: Top Ramen
Started stripping the front axle for the full hydro mods. I. This picture you can see I’m running the front range kit that flips the knuckles leaving the factory calliper mounts facing forward
Re: Top Ramen
Front unit bearing comes off with eight bolts once the calliper and rotor are removed
Re: Top Ramen
Reamed to 1/2 inch
Re: Top Ramen
Had my oldest son cut some parts for me. His first on the arcdroid
Re: Top Ramen
"why is there so much grease behind the ..... oh, that dumbass used Toyota axles"
Re: Top Ramen
Factory arms reamed to 3/4 to be ready for a weld in slug
Re: Top Ramen
Had the local machinist spin me up some inserts
Re: Top Ramen
Been picking away at the small things. But we got these mocked last with me drinking beer and cutting stuff on the table and jay drinking beer and mocking it up. Me and Brad got a plan for the beadlocks I think lol. Brad would remember he was sipping the Pepsi and on crowd control. As per usual there was a bunch people hanging out while we worked
Re: Top Ramen
so its like 70 days till may long, this going to be done in time?
Re: Top Ramen
it might be time to order a locker gears and bigger tires for the shop jalopy lol
