Hood hinges
HMF
Been Liked: 9 times
Hood hinges
Post by HMF »
Anyone know of some OEM hood hinge mechanisms that when the hood is lifted up it lifts the hood straight up and not up in a backwards arc like a stock Toyota hinge setup?
Need the hood to lift straight up on the truggy to clear the lower windshield bar of the cage and only want to use hood pins on the front so I can raise the hood by myself and not need 2 people every time I want to check something under the hood like I would with a 4 hood pin setup
Has Liked: 14 times
Been Liked: 8 times
Re: Hood hinges
its a toyota man just weld that bitch shut, wont need in there anyway.
Or if you insist on filling the washer fluid jug, you could fab her in lambo style backwards
Re: Hood hinges
Homeless Despot gate hinges?
HMF
Been Liked: 9 times
Re: Hood hinges
Post by HMF »
Scott Cee AKA 2drx4 wrote: Thu Jan 14, 2021 8:14 pm Homeless Despot gate hinges?
Needs to be a bit more complex than that :headbang: . I might have to model something up and see what I can hack togeather :popcorn:
HMF
Been Liked: 9 times
Re: Hood hinges
Post by HMF »
Johnny5 wrote: Thu Jan 14, 2021 7:01 pm its a toyota man just weld that bitch shut, wont need in there anyway.
Coming from the only guy I know that killed not one but 2 22re motors is short order
Been Liked: 45 times
Re: Hood hinges
Re: Hood hinges
Any old Chevy hood hinge actually moves the hood forward then up would work for you
Re: Hood hinges
Watch this
