Anyone know of some OEM hood hinge mechanisms that when the hood is lifted up it lifts the hood straight up and not up in a backwards arc like a stock Toyota hinge setup?
Need the hood to lift straight up on the truggy to clear the lower windshield bar of the cage and only want to use hood pins on the front so I can raise the hood by myself and not need 2 people every time I want to check something under the hood like I would with a 4 hood pin setup
Hood hinges
- Has Liked: 14 times
- Been Liked: 8 times
Re: Hood hinges
its a toyota man just weld that bitch shut, wont need in there anyway.
Or if you insist on filling the washer fluid jug, you could fab her in lambo style backwards
- Has Liked: 158 times
Re: Hood hinges
Needs to be a bit more complex than that
Re: Hood hinges
Coming from the only guy I know that killed not one but 2 22re motors is short order
- Been Liked: 49 times
Re: Hood hinges
Any old Chevy hood hinge actually moves the hood forward then up would work for you
