Vibrating parts washer project
I have been doing a ton of tear down and rebuilds of diffs lately. And the cleaning part was getting old so I started doing some research on a better cleaning solution of loose parts.
So here is my proof of concept
Steel paint can with cleaning solution and a palm sander zipped tied to it.
Tossed in a bucket of Toyota front axle contents including a few greasy wheel bearings
Ran it for half hourish
Re: Vibrating parts washer project
The wheel bearings came out with minimal grease still on them. The spindle nuts and washer came out surprisingly clean
Next up is a five gallon version
Has Liked: 78 times
That’s cool.
without fluid in there and loaded 3/4 full with nuts and bolts everything is just boiling in there. i might make something similar and load it with blasting media. Make it big enough to fit a steering knuckle
Put a stick on block heater on the bigger version. A little heat makes it work way better.
Scott Cee AKA 2drx4 wrote:Put a stick on block heater on the bigger version. A little heat makes it work way better.
That was my plan. Just running it over an hour with sander attached raised the temp almost twenty degrees
Are you trying to make a cheap DIY equivalent of an ultrasonic cleaner or is there supposed to be something this can do that an ultrasonic cleaner can't?
Basically that’s what I built without knowing what a ultrasonic cleaner was before I started this
