Porter Cable C5510 compressor up for sale. It's older, I bought it in 2005 maybe? But it's a good unit, it's actually quality built and weighs about 120lbs, and it's not been abused (except for the one time I lent it to Curtis Warner). Oiled single stage head, low RPM so it's very quiet, 150PSI max, 20 gallon tank, has a regulator attached. One of the tires leaks slowly, but the glory of it being an air compressor means you can refill it. And the contactor is worn out pretty bad, so I bodged it by flipping the leads, works as is but I'd probably recommend buying one eventually. Can be wired for 110V or 220V, it pulls a lot of amps on 110V because it actually has a pretty big motor on it, so keep that in mind.
Stock image. I'll upload the real ones eventually. But it looks like this but a little more beat up.
$250 special 4x4north price. I'm going to put it on the Fagbook for $350.
SOLD
Porter Cable 20 gallon air compressor - Sold
Re: Porter Cable 20 gallon air compressor
Lol except for that one time.Scott Cee AKA 2drx4 wrote:Porter Cable C5510 compressor up for sale. It's older, I bought it in 2005 maybe? But it's a good unit, it's actually quality built and weighs about 120lbs, and it's not been abused (except for the one time I lent it to Curtis Warner). Oiled single stage head, low RPM so it's very quiet, 150PSI max, 20 gallon tank, has a regulator attached. One of the tires leaks slowly, but the glory of it being an air compressor means you can refill it. And the contactor is worn out pretty bad, so I bodged it by flipping the leads, works as is but I'd probably recommend buying one eventually. Can be wired for 110V or 220V, it pulls a lot of amps on 110V because it actually has a pretty big motor on it, so keep that in mind.
