Howdy
Please introduce yourself here. You must make an introduction post before you can post on the rest of the forum.
Howdy
Hey it’s Andrew. I’m in Enderby and roll with a couple wj’s
Re: Howdy
Another familiar face. Good to see you're here. :canada:
Re: Howdy
Your ready for snow !!!
Re: Howdy
pointsnorth wrote: Sun Sep 22, 2019 9:50 pm Your ready for snow !!!
Pretty much. I’ve got insurance on the big guy this weekend. Was hoping for a shakedown run and bolt check before getting serious but hasn’t happened. Front Lokka inatallled. Rear wheel wells tubbed, should work ok. Buddy of mine built a couple push pads with tow points so we can stack 3 rigs together bump and run style.
Re: Howdy
Those are friggin genius
Re: Howdy
pointsnorth wrote: Mon Sep 23, 2019 7:16 am Those are friggin genius
Just need to redrill the pin hole. My hitch is turned 90 degrees so my pin drops in from the top. The JK pictured will do the same when he flush mounts his hitch. Then when on the road or after clearance we can spin them sideways as well.
Re: Howdy
Now that is a nifty idea. :ideas:
Re: Howdy
Thanks for the positive feedback on the push pads. Hopefully they work well. We’ve been talking about how to “attach” rigs together for quite a while and had some overly complex ideas but trying to get something to work with all the different angles and steering conditions when wheeling that have major drawbacks. When pushing on one point the back rig can steer the opposite direction of the front rig so they can be forced to steer instead of pushing the front rig straight off the corner. Found that out by trial and error. And if any ditches come up it’s easy for the back rig to back off and then pick the rig back up. Adding short tow straps helps not leave the push rig behind. Brian Steve and I got pretty good with straping 3 rigs together to maintain movement. Last year on one trip we went about 1.5km with 2 of 3 rigs stuck at all time yet made steady progress.
