The Welfare Duty
- Been Liked: 14 times
The Welfare Duty
Its a little over due but here is the build.
The truck started as a smashed up work truck I bought for $800.
Re: The Welfare Duty
Then it got it's frame cut down 18inches and got some used Deaver leafs and a flat deck off Erik's 79
Sent from my ELE-L04 using Tapatalk
We did our best to straighten out the accident damage. Then it got a modified forestry bumper
Stock fuel tank was mounted to the deck and stock fuel pump was modified hook up at a different angle
Truck got driven very hard and broke alot of Dana 50 axles so it got a Dana 60
At the same time as the 60 swap it got new tires , beadlocks and a bunch of TMR goodies
Sent from my ELE-L04 using Tapatalk-
With the new tires it was on to steering! Some DOM and some heim joint. Slap a little PSC ram on there and we have beefy hydro assist steering.
Sent from my ELE-L04 using Tapatalk- Scott Cee AKA 2drx4
Yeah the new transmission is all done. Works great!Scott Cee AKA 2drx4 wrote:You get your new built tranny in yet?
Raced the truck a lot and broke a bunch of stuff
After going through a couple rads I decided to change it up. Cut the old rad support out put in a rad out of a E350 van as it was shorter and solved my problems. Also put a transmission cooler for a 6.0l in and a bigger p/s cooler
With the new cooling package in I figured it build a skid plate and better grille protection. Built a Tcase skid plate at the same time
Finally got tired of breaking outer axles so I went with Yukon 35spline chromoly ones with TMR drive flanges. Machined the unit bearings to accept the bigger axle shaft
