Shop life hacks
Shop life hacks
Who uses a hand greaser anymore?
Re: Shop life hacks
Problem solved lol
Re: Shop life hacks
On a side note if your hose as even a slight leak or the smallest pin hole your going too know about hahaha
Re: Shop life hacks
I only have a hand grease gun. Result of not being allowed to use anything else at work. :rasta:
Re: Shop life hacks
A little something I came up with to straighten steel fuel line relatively quickly
Re: Shop life hacks
That line straightener is a good idea.
Re: Shop life hacks
I’ve got the Eastwood one for 3/16 and it works awesome I just can’t justify the 3/8 one as the shipping from Eastwood is brutal
Re: Shop life hacks
Scott Cee AKA 2drx4 wrote: Sun Apr 05, 2020 9:44 am That line straightener is a good idea.
Hell ya it is :thumbsup:
Re: Shop life hacks
Fluid transfer using a Chaplin deck sprayer and some brass fittings. Along with my transmission adapter kit this is awesome
Re: Shop life hacks
Hmm. That's a good idea.
Re: Shop life hacks
Scott Cee AKA 2drx4 wrote: Wed Jul 29, 2020 8:59 am Hmm. That's a good idea.
it makes filling some of these newer transmissions where you fill them thru the drain plug a much simpler and cleaner job
