The FSU trail buggy build
Re: The FSU trail buggy build
got the trailing arms built, still need to build the upper mounts
no fancy tig welds here. did wrap the end bushing as i had to cut and sleeve the link to extend it
parts for the front drive shaft showed up, will be 1410 cv shaft to 1410 joint at the steading bearing.
Seeing that shock setup brings the wood :pimp: :pimp:
Are you running a wobble stopper or just a bushing?
HillBilt wrote: Fri Mar 26, 2021 9:45 am Seeing that shock setup brings the wood :pimp: :pimp:
TMR anti wobble deals
SasquatchCdn
Web Wheeler
Been Liked: 12 times
Post by SasquatchCdn »
Shit yeah.
Trailing arms are looking slick!
What's your tentative goal for a shakedown run?
Snowracer wrote: Fri Mar 26, 2021 10:10 am
Hmm, those are neat.
SasquatchCdn wrote: Fri Mar 26, 2021 9:34 pm Shit yeah.
may long is what im shooting for, i think i can still make that happen but will be very bare bones with no skins or accessories ect
rear bump stop mounts, have 1/2 inch of clearance between links and bottom of fuel cell
put my efi back on the motor to see how my intake was going to fit. will be able to run it right back into the dash area but will need a small cowl on the hood to cover it
welded all my links and link brackets up and was able to take the buggy off jack stands and roll it around at full bump
Nice. :smokin:
Hell yes :pimp: :pimp:
that rear mounted light have the flashing lights in it or is it a super huge backup light?
pointsnorth wrote: Mon Apr 12, 2021 10:51 am that rear mounted light have the flashing lights in it or is it a super huge backup light?
its full douche chase bar with the amber strobes, brake lights and back up lights
1/2" steady bearing mount
HMF changed my lower rad fitting over so can run AN fittings top and bottom now
Snowracer wrote: Mon Apr 12, 2021 11:42 am
i needs me one of those
pointsnorth wrote: Mon Apr 12, 2021 2:23 pm
finished up the front drive shaft. its all 1410 ujoints so will be nice and beefy
can now really see how much of a clearance issue i have with the header, still think i can cut the header back and make it work
rear shaft is all girth no length as its 1480 joints and 3.5 tubing but like 2 feet long
