Picture of the day thread!
Talk about almost anything you want
Re: Picture of the day thread!
What's he doing in the rear?
Scott Cee AKA 2drx4 wrote: Mon Aug 01, 2022 9:02 pm What's he doing in the rear?
When he puts the rear diff in he’s pushing it rearward and will recut the wheel well. The inside tub is already as big as it can be. It’s from the seat mount to the back fender. It’s a bit rusty so there might be some sheetmetal work, but being an autobody tech he makes short work of that stuff.
Here’s 2 of the beat old wheels from the red wj. Spent some coffee breaks and lunch time after hours stiff at work with the sand blaster and powder coating
Fancy man that’ll look good on there
If you don’t have one buy one. You won’t know how you lived without one once you have one
Can you burn waste oil in that thing?
More info on that would be cool
Scott Cee AKA 2drx4 wrote:Can you burn waste oil in that thing?
You can burn engine oil in it but it soots up pretty bad if you filtered it it would be better. I only tried it with Diesel engine oil. I get used cooking oil from restaurants and cut it with diesel or kerosene for the best burn
Tire shop sent me updates while I was at work. Nice pick me up on a busy day
Seen this today. 44’s in a street radial mt. That’s awesome
Thunder goat , The mitsubishi Jeep finally going under the knife, Got his suspension and diffs assembled into pre fab stage as far as he could before taking it down for sugary. Holidays are leaving him enough time hopefully to get it assembled
For now he’s running my stock wj springs. Was talking about adding a 1-2” spacer for the time being so he can add longer springs later.
Looks like he's making a ton of progress. :smokin:
Scott Cee AKA 2drx4 wrote: Fri Dec 30, 2022 11:06 pm Looks like he's making a ton of progress. :smokin:
It’s been quite the project for him. Year and a half setting it up. From designing the suspension, buying parts as he could afford it, rebuilding the diffs, building new front fenders. He sent a video to me showing a staggeringly large amount of play in the Mitsubishi front end wheel bearings and tie rods. Was definitely time to swap it over.
