Durkota
Re: Durkota
Tired tonight so didnt get much done but trying to update this thing everyday until its done. X members back in the truck mounted my bling flywheel and got my clutch but need to sweet talk hmf into spinning me an adaptor for the pilot bearing to go in the torque converter hole
- Has Liked: 14 times
- Been Liked: 8 times
Re: Durkota
Hey there just cause it’s gonna make that much don’t mean it all goes to the wheels, being a dodge you know they gotta turn half that into just noise
Re: Durkota
Just made clearance for the 205 tonight as it hangs a bit low. Kind of messed up my measurements and heaven forbid I make a new piece. so just scabbed some more steel in there in proper ramcharger fashion.
Re: Durkota
Hopefully the last time the engine is bolted in place. Clutch is on. Was going to clearance the oil pan to panhard via cuting and welding but will probably do the old hammer and wood method instead.
Re: Durkota
I think im going to end up doing an exo. I have to do something for sure as i took too many crossmembers out.
Re: Durkota
Just one from the shock hoops dont have plans to go from engine mounts right nowpointsnorth wrote: ↑Fri Nov 01, 2019 12:28 pm are you going to do a crossmember at the engine mounts?
Re: Durkota
Dicked with the engine mounts today, built a pushrod for the clutch im using the factory dakota master and slave. It took 3 tries to get the correct length because i forgot how hydraulics worked apparently. Then started painting crap. Hopefully last of my engine parts show up this week.
