Winches
- Been Liked: 92 times
Re: Winches
think i might have just found what im after
Bulldog Wiches makes a comp winch that has a 6.8hp motor and 138-1 ratio.
55 feet/min at 0lbs
11.2 feet/min at 8,000lbs
and is just over the budget by $90 haha
does have the smaller drum but says still holds 75 feet of rope, not very often ive had the full 90 feet out on my M15
55 feet/min at 0lbs
- Has Liked: 78 times
Re: Winches
That sounds about right. Pack a 50’ tag line. Not often I’ve needed to winch more than 100’ and it was 350 foot winching when I broke an axle. Usually it’s a few foot pull to get out. As long as you have the gear to reach the anchor pointSnowracer wrote: ↑Fri Nov 08, 2019 4:22 pm think i might have just found what im after
55 feet/min at 0lbs
does have the smaller drum but says still holds 75 feet of rope, not very often ive had the full 90 fee out on my M15
Re: Winches
idea with getting a new faster winch is for racing ect. will take one of my old slow ass winches and put it on the back so will be able to run 100 feet out the back and pull my ass out and run away from what ever i got stuck inScoobienorth wrote: ↑Fri Nov 08, 2019 4:27 pmThat sounds about right. Pack a 50’ tag line. Not often I’ve needed to winch more than 100’ and it was 350 foot winching when I broke an axle. Usually it’s a few foot pull to get out. As long as you have the gear to reach the anchor pointSnowracer wrote: ↑Fri Nov 08, 2019 4:22 pm think i might have just found what im after
55 feet/min at 0lbs
Re: Winches
Your budget limits it. A Warn Zeon 10 is about $1500 on Amazon.ca, so probably find it for less (is Ford a Warn dealer????), but the 10-S is $1800... I'm assuming you want synthetic because only the trail rigs or really poor people run steel now.
My 8274 comparison was only because I fully believe that the other winch manufacturers lie about their speeds.
Re: Winches
looking at the warn winches on paper there is no real difference on speeds or ratings between the VR (cheapest) and the Zeon or Zeon premiums as same motor and gearing. its just going to be fit and finish and warranty ect. and yes i can get the Warns for less then that through workScott Cee AKA 2drx4 wrote: ↑Fri Nov 08, 2019 4:49 pm Your budget limits it. A Warn Zeon 10 is about $1500 on Amazon.ca, so probably find it for less (is Ford a Warn dealer????), but the 10-S is $1800... I'm assuming you want synthetic because only the trail rigs or really poor people run steel now.
im with you on the speeds not sounding right as on paper the shitybuilts look fast but have used them and meh speed wise
oh and im very much a poor person and want steel cable. buddy tried some rope on his 9.5 and it fucked up just trying to pull a tree out of my garden the first time he used it so ill stick with my old school killer cable
Re: Winches
Oddly the VR EVO runs a different planetary and probably different motor. I'm guessing they're intended to be the real budget line now? Lots slower, but cheap, under $800 on Amazon for the 10000lb with steel cable.Snowracer wrote: ↑Fri Nov 08, 2019 4:55 pmlooking at the warn winches on paper there is no real difference on speeds or ratings between the VR (cheapest) and the Zeon or Zeon premiums as same motor and gearing. its just going to be fit and finish and warranty ect. and yes i can get the Warns for less then that through workScott Cee AKA 2drx4 wrote: ↑Fri Nov 08, 2019 4:49 pm Your budget limits it. A Warn Zeon 10 is about $1500 on Amazon.ca, so probably find it for less (is Ford a Warn dealer????), but the 10-S is $1800... I'm assuming you want synthetic because only the trail rigs or really poor people run steel now.
Get a VR 10 then? $890 on Amazon, means you're probably looking at $600.
Pulling a tree out sounds like trail rig type shit though, not competition use. But I'm with you on synthetic sucking for most use, there's a reason I run steel cable and synthetic extensions. Since the extension hardly ever gets used, and you're not actually sucking it into the winch (hopefully) and the fairlead and crap on it often do a bunch of the damage, the synthetic extension doesn't get tore up anywhere near as fast, but they're nicer to pack and handle.
Re: Winches
Does anyone know the duty cycles for the VR vs M series?
I got a m8000 thats been through some tough stuff and never stops running.
I ran my m8000 for hours trying to winch up a hill last year in the snow that I shouldn't of went down in the first place
I'm lucky that winch kept working or that would of been a LONG walk out.
The prices on winches has skyrocketed compared to about 5 years ago when I bought mine.
Shittybuilt 9.5 is only 470$ on amazon right now.
Re: Winches
Is that the warn 9.5xp motor? Its a pricey motor but thats what I plan to run as I already have 2 or 3 8274spointsnorth wrote: ↑Fri Nov 08, 2019 4:07 pm If that’s the case isn’t there a 6.0 hp upgrade for the 8274 that should fit any of the other warn winches?
Re: Winches
Late to the party here, Im not sure on cost on them today, but I run a warn 9.5Ti and its a great in between for speed. Its quite a bit faster than that other winches listed but not 8274 speeds. Talk to Brad, hes seen it in action, its respectably fast.
Re: Winches
looking at that winch (now the 9.5cti) its pretty fast as has 156-1 ratio so would be 47 feet/min at 0lbs and 5.9 feet/min at 9500lbs. but quite a bit over what im looking to spend, might have to start saving my pennies
Re: Winches
so im still on this whole winch thing
leaning really hard towards the Bulldog comp winch. biggest thing against it was the fact that it only came with 75 feet of rope on it. but after going back and looking at all the new Warns (VR Evo, Zeon, Zeon Platinum) they dont eve come with 100feet on them anymore. Most of them are 80-90 feet, have to get into the older style winches to get 100 feet of cable. my old M15 only has 90 feet as well and not very often im running that much cable out. Looking at more specs the bulldog winch also pulls less amps at all weights then the warn ones do as well so thats kinda nice as less load on the electrical system
Re: Winches
Just pack a tag line. Winching or respooling 100 feet sucks anyways. How often do you winch more than 60 feet.
