2020 Insanity Fab Winter Challenge Prep
Been Liked: 87 times
Re: 2020 Insanity Fab Winter Challenge Prep
the wang wheel was better
Snowracer wrote: Thu Oct 24, 2019 3:45 pm the wang wheel was better
:lmao: :lmao: Tough to get to the lug nuts though
Are the chickens getting etched in?
Mr.gutsy wrote: Thu Oct 24, 2019 10:34 pm Are the chickens getting etched in?
Yeah, and painted gold
Has Liked: 153 times
HillBilt wrote: Fri Oct 25, 2019 12:35 pm
:lmao:
Has Liked: 42 times
Better be rocking Burt’s signature facial hair to pull that off at insanity fab. Hell they might just give you the trophy.
pointsnorth wrote: Fri Oct 25, 2019 2:33 pm Better be rocking Burt’s signature facial hair to pull that off at insanity fab. Hell they might just give you the trophy.
You know me too well. Of course Ill be rocking the Burt :cool:
:smokin: the stache grows in as soon as you turn the key in that bad boy
I got my ass in gear a pulled the trans and Tcase out Friday night.
Got the ole StaK O Shit on the bench for a tear down inspection. Ive been on a waiting list from TWF for a few years for a replacement range shaft and wasnt going to purchase it until I had a look inside at the internals to see if it was even worth it
Turns out its all good to go, other than a snap ring that had come out and let the high range gear move back a Jiff, which is most likely why the rear has been pooping out in high range, seated the snap ring back in
and gave it an expensive oil bath
finally got started on my pos
rear disc brake swap as pretty much had zero rear brakes the last two time have gone out :homer:
Has Liked: 42 times
is that akit or something you can swap on from a newer axle
pointsnorth wrote: Tue Oct 29, 2019 8:23 am is that akit or something you can swap on from a newer axle
kit kinda. bought the brackets and its uses Ford Van rear rotors as the vans are still 8x6.5 not metric. then Chevy front rotors and pads, some Stainless lines and you are done
Snowracer wrote: Tue Oct 29, 2019 8:49 am
Chevys, always making Fords better :flipoff: Probably save some weight too :smokin:
Started the tear down/case swap. Donor Trans, hopefully the case is in good shape after a clean up
Got most of the guts out and look in decent shape. Might get my old case welded up and slap these parts into it
Didn't have a 12 point 3/8 socket so as far as I got last night, all that's left is the last drum and tail shaft assembly
Has Liked: 42 times
Snowracer wrote: Tue Oct 29, 2019 8:18 am finally got started on my pos
were you running the spacers with the drums as well or are you trying to get more track width now
