The Welfare Duty
- Been Liked: 14 times
Re: The Welfare Duty
Then put on limiting straps for the times the truck gets aired out
Sent from my ELE-L04 using Tapatalk-
Well I decided to enter Insanity Fab Winter Challenge.....and decided why not completely re-work the truck. So it got trussed diffs front and rear, 5:38 gears, 3 link up front with 2.5x14 Fox coilovers. Out back and an exo cage
The cage and mini boat sides. I think it was like 5-1/2inches off the bottom of the cab
We got it all together and went for a trial run. Worked great but I'm hard on stuff. Broke the front 60 and twisted the truss all up. With a week before we had to go to Idaho.
After talking it over with friends we decided to push and try to fix it. That night I drove to Houston and got another diff the next day had it stripped down. Then I passed it over to Jordon at HMF and he built a new beefier truss. We got the diff back and Sean and I swapped gears from one diff to the new one.
We got it all together and a hot lap around the block and off to Idaho. The race was a blast. The truck got flipped on its side, wrecked a door, broke the driver's side Knuckle and broke the sector shaft off the steering box. Oh plus got a flat steer tire
Home from the race it was time to fix it. New knuckle, steering box, rear leafs and shackles, door, tire and it was ready to rally some more
Because we were doing more racing I decided to finish the cage and upgrade my seats
Then I flopped the truck again just out for a Sunday cruise. I had to test the cage to make sure it works right
So the truck got a face lift! Time for new body panels and some paint! Plus some sponsorship decals!
A LOT! of stuffHillBilt wrote:Geezus you've broke a lot of stuff and were not even to the end of the story yet
With the truck looking all new! It was off to Tail Creek race. Was a blast really fun race and we managed to come home with a 2nd place, fastest pass, and a broken truck! Do you know what happens when you jump a 7000lb truck not knowing your bump stops are torn off!
