Ford oil pan rough dimensions
- Been Liked: 19 times
Re: Ford oil pan rough dimensions
Ford 300 oil pan is what you need. Approx 24" long, flat flange other than the main caps front and rear and it's a deep rear sump. I'll take measurements when I get home.
Haha, I remembered this time.
The pan is between 29 and 29.5 freedom units long and a little under 12 freedom units wide at the widest point.
- Attachments
- FP02A.jpg (9.29 KiB) Viewed 3120 times
- Has Liked: 158 times
I think it's too long.
I think the V8 pan is more likely to be close, as it will be shorter. This is not an I6 engine, only has 5 cylinders. Plus the V8 pan is flat flange.
I may just order one and hope for the best.
