Stripper glitter
Has Liked: 78 times
Re: Stripper glitter
Well I can’t get a good pic of it but I had some time at work and powder coated my rack setup since I can’t weld aluminum so I won’t be changing it. The outside rack that you can see is mirror black with an iridescent aquamarine top coat so it’s basically dark green metallic in the light and black in the dark. The under cover parts I did boring old wrinkle black.
Has Liked: 78 times
I bypassed the second battery. Vehicle seems to be charging more than it should but it’s within spec. Did a big service, changed diff oils and tcase fluid. Then I cut up my front bfg’s. Trying to get them to shed slush and stuff a bit better. They’ve never been great but now at 50% tread or just under it’s worse. I’d like to sipe the middle blocks but didn’t have time. The rears I might groove the middle blocks as well.
Fairly mild cut with #4 blade
Before pic
Has Liked: 78 times
Black Friday sales got me. I’ve thought of trading this in on a bigger truck and a small car for commuting but I couldn’t find much that I wanted. So I ordered a bigger better rooftop tent, 40L 12v cooler and Jackery 500 to power it. I’m going to have to rebuild my whole box setup, doing one full box slide drawer and probably something like a 3/4 height canopy for the tent to sit on. Maybe have the kitchen above the box on the drivers side on a fold out table type of idea perhaps.
Has Liked: 78 times
Man got a warning for everything. It says “performance may be limited use one pedal at a time “
I was teaching my daughter manji slides on the airport and I was getting pretty aggressive in 4hi and dabbing the left foot braking mid corner to pick up the rotation speed. Apparently I had a little overlap in the pedal operation
It doesn't want you to hurt it. :laughing:
Has Liked: 78 times
Lost a mopar led headlight to a rock strike. Blasted my window out as well and the side of it. Expensive hit. Removed the grill and headlight, removed the rock and taped it up to try and keep it working until I get a new one or something anyways
