Ford 8.8 limited slip clutches
So the limited slip in my 8.8 feels pretty weak by hand. I'll probably leave it alone and wait until I see if it works before I do anything. However, there is rebuild clutches for it.
Available on Rockauto:
Not super cheap. I'm assuming the more you pay the more you play.
Is there anything else out there? Any experience with any of these?
Re: Ford 8.8 limited slip clutches
Also, there is a Ford Racing kit on Amazon, P/N M4700C for about $270 Prime. Carbon disks, good reviews, looks like it fits the Exploder. What's not to hate?
The Yukon ones, P/N YPKF8.8-PC, are also on there for $183. Commentors say they are "just as good" as the Ford racing ones. Hmm.
Scott Cee AKA 2drx4 wrote: Sat Feb 24, 2024 4:27 pm Not super cheap. I'm assuming the more you pay the more you play.
They're all roughly the same. The trick is to cram more clutches in there. Should be a write up on a mustang forum somewhere.
when worked at ford we had tool kit to compress the clutch packs to be able to put more in
arse_sidewards wrote: Mon Feb 26, 2024 3:15 am
Carbon probably lasts longer if you're getting it real hot, I guess?
So buy the cheap ones and try to jam them in with the ones that are already there? :homer:
