- Has Liked: 76 times
- Been Liked: 70 times
44” boggers make everything look cool. But this thing is really awesome. Glad to see it come together
- Been Liked: 87 times
Scoobienorth wrote: ↑Mon Apr 24, 2023 5:51 pm 44” boggers make everything look cool. But this thing is really awesome. Glad to see it come together
boggers sure do make every thing better
did have a moment last night where i pondered just living the lame 40" life
so got cut happy again and made some room for the 44s
- Has Liked: 153 times
was finally able to get this thing done enought for a shake down run. worked better then i expected and pretty happy with it as only a few small things to fix and should be good to go again
not going to lie its pretty awesome having a box agian and not a flat deck even if have to climb up to get trail drinks
best part is i drove for maybe the first hour just to make sure everything was good then turn the wheel over to the gf and she was pumped. ill probably never get to drive agian
so after the shake down run i had a few issues to deal with so been working on that. had to pull the tcase again as was leaking gear oil from the trans to tcase gasket. also been fighting steering box issues non stop with this build. the F53 pump is putting to much psi and the box is bypassing and causes it to turn passenger on its own. swapped a borrowed box in for the shake down run and it worked well for the first bit of the day then stared to bypass and also leaked like crazy buy the end of the day. so i rebuild my box and swapped it and it bypassed as well even after a fresh rebuild. instead of swapping back to a stock pump i just said f it and swapped to full hydro. single ended ram kinda sucks but will work for now till i can by a double ended and swap that in. few small things to clean up tonight and should be ready for maylong wheeling
No way to adjust the pressure on that pump? I guess plowing ahead with full hydro is better in the long run anyway.
the pump does have a regulator and relief built in and yes i could have put an inline one to lower it more. Im running an inline relief valve on the buggy as pump does not have one. truck was going to wind up full hydro down the road this just speed that up by a year or soScott Cee AKA 2drx4 wrote: ↑Tue May 16, 2023 9:28 pm No way to adjust the pressure on that pump? I guess plowing ahead with full hydro is better in the long run anyway.
just for extra info i found some more specs on the f53 pump vs the c11 stock pump
F53 rated at 3.66 gpm and 1799psi relief
C11 rated at 1.46 gpm and 1400psi relief
so its not so much the pump pressure that is causing my issues, more the flow rate and the box cant handle the extra fluid and it will build more pressure in the box as fluid cant flow through the box and builds pressure till it bypasses
Interesting. So I guess it's too much of a good thing. Maybe a ported box could handle it better.
Priority divider valve.
Use the extra flow for hydroboost or a hydraulic fan or something.
so may long was a success even if we broke some stuff. busted a tie rod off, peeled the tire off the inner bead and broke the winch line first day. motor mount went and was letting the motor move around and smashed the header in. had to take it easy on the throttle to keep that in control. otherwise i learned the truck needs rear traction bar and more power for sure
pics just cause
pics just cause
whipped up some new motor mounts that hopefully fix my issues
new inner axle on the drive side as it was warn and dicked the seal enough to leak
all loaded and ready to go see what brakes this weekend
been a bit since ive worked on this pos but snow is falling so time to get this thing ready for winter wheeling.
front drive shaft has been kissing the trans crossmember so built a new crossmember to fix that issue.
went with the double barrel shot gun look to start with.
about the same height as the stock one just farther back to clear the shaft
