Ford Ranger leaf springs?
Has Liked: 153 times
Does anyone actually lift Ford Rangers? Rockauto says 83-03 would be the years that use the same rear spring, and I'm looking for a 3" lift version of them.
Or is every Ford Ranger out there lifted with a cobbled collection of stacked blocks and random bits of rebar?
Re: Ford Ranger leaf springs?
The market for lift springs is slim because Chevy 63s work really damn well in these trucks (only need to move the front hanger) so that's what a ton of people go with.
Also, springs up through '11 probably work. Dimensions should be the same. Difference is probably in the bolt sizes.
Interesting, the later springs are basically the same, just 3/16" longer (allegedly). I can't find the bolt hole size anywhere though.
Been Liked: 87 times
hard to find a small lift spring for rangers as most do bastard packs, 6" lift leafs or swap to chevy springs
No way Chevy 63s net you a full 6"
If they do you can always swap them in and then flip the rear shackle so it's in tension.
arse_sidewards wrote: Wed Jan 19, 2022 10:15 am No way Chevy 63s net you a full 6"
I want them to go SOA in a Comanche without getting 6-7" of lift.
There's another GM spring that might work, but it looks like it would be too tall too.
Has Liked: 42 times
If your looking to go with ranger springs I’ve got one brand new oem spring pack here customer had parts shipped to my door and Amazon lost one spring and sent him two more. Yours for a case beer
Why not go SUA with a pack that's too tall?
You'll get better pack life that way anyway since you'll never have the pack go negative.
pointsnorth wrote: Wed Jan 19, 2022 11:32 am If your looking to go with ranger springs I’ve got one brand new oem spring pack here customer had parts shipped to my door and Amazon lost one spring and sent him two more. Yours for a case beer
Which spring rate or P/N is it? Any idea? I might want it and just use it with a zero rate and a longer shackle, or something.
arse_sidewards wrote: Wed Jan 19, 2022 12:53 pm Why not go SUA with a pack that's too tall?
The static arch is 10.25" to start with. So to get the lift I want you've either got to go up in rate bunch, or go to something like 13-14" of static arch. I'm not sure if it's a bad idea really, I could add a leaf and go with a longer shackle, but the springs I have are thundered, and they're quite expensive to buy new. I'm not sure.
Also, I plan to run an overload and bumpstops either way, I'll contact things before a SOA pack goes negative most likely. I think. I'd have to measure some stuff for sure.
Has Liked: 42 times
ill try and make it out to the seacan today and dig up a part number. its was a dorman number
pointsnorth wrote: Tue Jan 25, 2022 8:43 am ill try and make it out to the seacan today and dig up a part number. its was a dorman number
Anyone driving this way? I'm pretty tempted to take it regardless, because I can at least eyeball it up.
