The build portal just opened today. Not sure on much yet. I’ve been bugging them weekly though.
Picture of the day thread!
Re: Picture of the day thread!
Seen this local. Super clean 6.2 diesel half ton 2wd. Not sure what they are asking.
Hopefully not much. The only way it could be worse is if it was three on the tree and a shortbed.Scoobienorth wrote: ↑Thu Sep 23, 2021 9:03 pm BFEDA432-550E-4149-A8E8-7070913FF481.jpeg
I'd totally rock a short box diesel with three on the tree... it would be fun.arse_sidewards wrote: ↑Tue Sep 28, 2021 3:59 amHopefully not much. The only way it could be worse is if it was three on the tree and a shortbed.Scoobienorth wrote: ↑Thu Sep 23, 2021 9:03 pm BFEDA432-550E-4149-A8E8-7070913FF481.jpeg
Tried getting up to a high spot in a winter block with the tj and the family to get setup to glass. I was hoping to cut the wife’s moose tag. Ended up being an evening of full pull winching getting in and out. The second picture is a winch up onto a creek crossing as the piled logs were the only solid ground
My skinny 32’s mounted up full of air on one side, 37’s at 20 psi on the other and the tires for my tundra in the middle. 285/75r18, 35x11.5(ish) can’t get suspension yet for it. What I want is back ordered. Might try and fit the tires at stock height with some minor manipulation. Might need the lift though
Well the new Jeep gladiator showed up. Pick it up tomorrow and drive it home. Got the new tires for it at home. Just need some lift parts first
Did the torsion bar delete on my Ranger. Kit from Sportsman and Baby Fox Coilovers. Pretty happy with it so far. I took no pics, the bottom pic is actually from Brady at Sportsman to show me what to cut out, mine looks the same just not all painted nice
pretty much, but was kind of my fault as I didn't specify that I had a lift in the truck so the first set that showed up in June were too short.pointsnorth wrote: ↑Tue Oct 26, 2021 10:34 am how long has it been waiting on the coil overs? two years
- Forum Newbie
- Been Liked: 2 times
Guess this is my photo of the day. Local dealership posted my clapped out crushed beer can of a landcruiser on social media.
Sent from my Pixel 2 using Tapatalk
Then we got out onto a pipeline right away and tried a couple deacs and couldn’t quite make it. Eventually got one but couldn’t get through the second one. Apparently I got some alarms for trying there to. Then we went out and found another camp spot and let her drive the tundra back on the pipeline. She turned 10. Loves the sound of the v8.
Little video of her driving. Missed the spot where she stopped put the truck in neutral and revved it up to 4 grand to hear the v8 rumble
