So island cup wasn't a go. Turned into a local invite only race with no spectators, really gay.
I doubt the rules are gonna ease up all that much before spring so hopefully they just go ahead with next year regardless. Not hopefull though :( :(
In the meantime I wheeled the shit out of the ftoy this year, raced Quesnel twice and came home with a win both times!
After the Sept 25th race I put it up on blocks and sold the Toyota diffs, in the process of putting together a set of superduty diffs for it this winter.
Front is an 05+ super 60 front, cut and swapped the axle tubes for Toyota offset, 5.13 gears, welded, 2.75x10" PSC full hydro ram, 1550 f450 shafts, redrilling to 8x6.5 and fitting sterling rear calipers so I can run 16's, triangulated 4 link with radflo 2" remote resevoir coilovers.
Rear is a 10+ sterling 10.5, 5.13, factory e-locker.
Keeping the rear leafs for now.
Goodbye Toyota diffs
Scored some 42" iroks and built some weld on beadlocks.
Wrapping the inner bead with a few wraps of pilsner duck tape....
![Image](http://emoji.tapatalk-cdn.com/emoji481.png)
Axle is stripped, tubes are swapped, just working on mocking up link mounts, truss and hydro mount with the help of some "cardboard assisted design"
![Image](//uploads.tapatalk-cdn.com/20201228/6366f531a5dd4217b6d0b2ca85439f19.jpg)
