The Welfare Duty
WelfareDuty
Web Wheeler
Been Liked: 14 times
The Welfare Duty
Post by WelfareDuty »
Its a little over due but here is the build.
The truck started as a smashed up work truck I bought for $800.ImageImage
WelfareDuty
Web Wheeler
Re: The Welfare Duty
Then it got it's frame cut down 18inches and got some used Deaver leafs and a flat deck off Erik's 79ImageImageImageImage
Sent from my ELE-L04 using Tapatalk
WelfareDuty
Web Wheeler
We did our best to straighten out the accident damage. Then it got a modified forestry bumper ImageImageImageImageImageImage
WelfareDuty
Web Wheeler
Welded some diffs and got some XMLsImageImageImageImage
WelfareDuty
Web Wheeler
Stock fuel tank was mounted to the deck and stock fuel pump was modified hook up at a different angle ImageImageImage
WelfareDuty
Web Wheeler
Time for a winchImageImageImage
WelfareDuty
Web Wheeler
Truck got driven very hard and broke alot of Dana 50 axles so it got a Dana 60ImageImageImageImageImageImage
WelfareDuty
Web Wheeler
At the same time as the 60 swap it got new tires , beadlocks and a bunch of TMR goodies
WelfareDuty
Web Wheeler
With the new tires it was on to steering! Some DOM and some heim joint. Slap a little PSC ram on there and we have beefy hydro assist steering.
You get your new built tranny in yet?
WelfareDuty
Web Wheeler
Scott Cee AKA 2drx4 wrote:You get your new built tranny in yet?
Yeah the new transmission is all done. Works great!
WelfareDuty
Web Wheeler
Raced the truck a lot and broke a bunch of stuff
WelfareDuty
Web Wheeler
After going through a couple rads I decided to change it up. Cut the old rad support out put in a rad out of a E350 van as it was shorter and solved my problems. Also put a transmission cooler for a 6.0l in and a bigger p/s cooler
WelfareDuty
Web Wheeler
With the new cooling package in I figured it build a skid plate and better grille protection. Built a Tcase skid plate at the same time
WelfareDuty
Web Wheeler
Finally got tired of breaking outer axles so I went with Yukon 35spline chromoly ones with TMR drive flanges. Machined the unit bearings to accept the bigger axle shaft
