HudsonBay Bomber
Re: HudsonBay Bomber
Whats that belt run? Cant help but think Id want to ziptie a new one around the driveshaft or something. That looks like a pain to replace in -20
Mr.gutsy wrote: Thu Oct 29, 2020 10:04 pm Whats that belt run? Cant help but think Id want to ziptie a new one around the driveshaft or something. That looks like a pain to replace in -20
The belt runs a hydro pump for the front diff oil. And I already plan on staging a belt. Drive shaft just need to be removed on the diff end to get it on.
TrophyRat runs one as well
pointsnorth wrote: Fri Oct 30, 2020 10:03 am TrophyRat runs one as well
So you're saying this thing is basically a trophy truck in disguise? :smokin:
Scott Cee AKA 2drx4 wrote: Fri Oct 30, 2020 11:59 am
Participation Trophy truck maybe
Removed the rear hydro valve block and lines on the “passenger side”
Took one of the seats from the back of my ranger as I had removed them awhile ago. Aside from having to build some oddball mounts should work mint
Pulled the factory mount off and did some mock up
Actually fits decent can see the foot stop up front
Cleaned up some more grime and opened up the front diff. Oil is junk, but all looks good for the most part. Brake bands in fair shape should be good for a bit. Will clean it up and drain the lines and cooler and splash in some new oil.
Can see the planetaries, brake bands and drums. That’s all it uses for steering and braking. R/P is just a D44.
Has Liked: 14 times
Been Liked: 8 times
Neat haha its like a super tiny dozer without clutch packs
Just ordered this up. See how long it takes to get here...
Has Liked: 14 times
Been Liked: 8 times
Always been curious about those efi set ups.
Hope it comes in a decent time. Last thing i ordered they lost it and just gave me money back. Like 2 months waiting
I didn't realize they made them for those little baby motors. It should work good though, based on how well the V8 version works.
Johnny5 wrote: Tue Nov 03, 2020 6:44 pm Always been curious about those efi set ups.
Scott Cee AKA 2drx4 wrote: Tue Nov 03, 2020 11:49 pm I didn't realize they made them for those little baby motors. It should work good though, based on how well the V8 version works.
Holley just released it a few months ago. I hope it works well, will save me alot of time jetting and tuning for altitude with a carb. like you said if it works as well as the other setups should be mint, as I feel they have the systems pretty much dialed now
New drive sprockets showed up today
Finally started making sparks on this thing. Removed the heater and valve block to clean them up and sprayed some bedliner under them.
Beefed up the ram mount and added another hole for the pin for the winch mount I plan to build
Whipped up the foot stops and tied them into the side to help beef up the area where I plan to mount the roof rack and running board step
Other side has the cables for the hydro lines so had to go around them
HMF stencils for the win
