- Been Liked: 87 times
those locking dipsticks? been thinking about getting one for my trans and trying to make my engine one into a locking one some how as cant buy one to fit my oil pan
- Has Liked: 153 times
Interesting. I've always been suspicious of those clamps and that would confirm my fears.
Yeah both of them. Been long over due, my trans is one I sourced from the junkyard as all aftermarket cheap stuff is shit and motor one spits out when shes hitting the high Rs. Theyre pimp
Yeah, they have their place, but I was hoping they would hold up a bit better. Only driven the truck a handfull of times since I installed them. Im just going to bend them back strait and weld the bottom clamp up. Will just have to zip cut the weld when I have to remove it for nowScott Cee AKA 2drx4 wrote: ↑Wed Nov 13, 2019 11:09 amInteresting. I've always been suspicious of those clamps and that would confirm my fears.
- Has Liked: 42 times
I plan to change my trans cooler lines to rubber hydraulic lines. Swapped the pump fittings on the transmission to accept the new lines. Upped the line size by a bit also.
Hahaha, right!HMF wrote:Nice that should help not spray red gold everywhere
You going to tie into the shock mounts in the back then?
yes thats the plan. will cut the a pillar/roof bars back flush and Mr HMF is going to make me weld slugs so i can sleeve the down bars onto themScott Cee AKA 2drx4 wrote: ↑Mon Nov 18, 2019 9:11 amYou going to tie into the shock mounts in the back then?
HMF killed it on my H1 re-center kit now I have to find some PVC for inserts
