Smittybuilt 2781 mod
Gear, Equipment, Towing, Trailers, etc - Basically anything that's not actually the 4x4 but is necessary to go 4x4ing
Well I modified the chuck and as the smittybuilt end won’t go over my J-flators which is why I originally put dual valve stems in my steel wheels. My aluminum wheels I don’t want to go that route. So I pulled the guts out of a clip on tire end as to not dead head the compressor. Since then I started freezing up on the smittybuilt gauge/bleed down. Now it’s12.5 feet of 5/16 transmission line right to the valve stem. The compressor was always faster without the curly hose. It’s dumb easy to take apart. It’s just a spring over a barn fitting. Pull the spring back and it slides apart. Should air up pretty fast especially as the J-flator flows more air than the standard valve stem as well.
Re: Smittybuilt 2781 mod
Makes sense to do it that way.
Never clocked how long it took before but it’s noticeably quicker. Steves 35” tires on 16” rims took 2 mins 10 seconds from 2-20 psi. The hose is a lot less of a fight to. Definitely a good mod for these compressors. Run cooler to.
