Soft Shackles
Gear, Equipment, Towing, Trailers, etc - Basically anything that's not actually the 4x4 but is necessary to go 4x4ing
Soft Shackles
Who is using them, and have you found they hold up well?
I bought a couple buy honestly never take them with me. The only place they seem to make sense is for combining two recovery or tow straps.
Been Liked: 48 times
Re: Soft Shackles
I like this idea of using the soft shackle as a snatch block
Re: Soft Shackles
I’d assume you would use that with synthetic rope
Re: Soft Shackles
pointsnorth wrote: Sun Sep 22, 2019 2:04 pm I’d assume you would use that with synthetic rope
I think you'd have to. I'm not sure how good that would be for the rope of the shackle either way. Seems like it's asking to friction burn it, especially if it's not perfectly clean. I'd certainly be curious to see it done though.
Has Liked: 84 times
Re: Soft Shackles
I’ve got a soft shackle. Haven’t used it much.
Junkjunk
Re: Soft Shackles
Post by Junkjunk »
I keep a set of soft shackles and 20ft kinetic rope in my 1500 and the wifes zr2 and have used them probably a dozen times. Had no problems and they seem to be holding together just fine. Pulled a couple power wagons out and 1/2 tons as well. Usualy snow wheeling/exploring so no real nasty yanks out of a mud pit or nothing. I'm definitely cautious of where I hook them because I worry they will cut . But so far so good!!
Sent from my SM-G965W using Tapatalk
