Page 1 of 2
Not a jeep person
Posted: Mon Apr 20, 2020 6:13 pm
by ridenby
Started with a M1028, pretty nice one at that.
Got some front springs , shackle flip, cross over steering, started install all that. Got some hummv wheels and tires from Trail Worthy fab.
Re: Not a jeep person
Posted: Mon Apr 20, 2020 6:51 pm
Nice.
What next?
Posted: Tue Apr 21, 2020 7:23 am
MOAR
Posted: Tue Apr 21, 2020 8:34 am
Nice build post up more
Posted: Tue Apr 21, 2020 9:51 am
by ridenby
Went riding a few times. Found a few weak links. Was a little stiff in the steering. Had a trac-loc limited slip from the factory. Pick a wheel up in front and it was done. Decided a locker was needed. Went with a Grizzly, Yukon locking hubs. When I pulled the axles one u-joint was so stiff I could not bend it. Found a fellow selling RCV axles. Did king pins, bearings, spindles, cause why not,in there anyway. While I had the axle out went on and changed the cross member and engine mounts to ORD. Put an ORD steering brace in too. Used DIY4x4 rear shock mount.
Got a winch mount welded on the brush guard, Cheap 12000lbs china winch mounted to it.
trac-loc that was removed.
Why I drive a truck rather than do photography for fun money.
Posted: Tue Apr 21, 2020 9:54 am
by ridenby
I gathered up a few tools that beat the tar out of pry bars and cussing
Posted: Tue Apr 21, 2020 11:03 am
by Provience
awesome
what's the deal with the case spreaders? is it just an extra couple thou that it is able to flex the housing? looks like a pretty simple tool if it works good
Posted: Tue Apr 21, 2020 12:37 pm
I really like how you incorporated the winch mount with the factory bumper/bush bar, looks good.
Are all CUCV trucks diesel? pardon my ignorance but we dont really have any cool army shit up here
Posted: Wed Apr 22, 2020 5:38 am
by ridenby
Provience wrote: ↑Tue Apr 21, 2020 11:03 am
awesome
Yes, once a little pressure is applied the carrier just comes right out or in. Get crazy with it and it can spring on even crack the housing,I am told.
Posted: Wed Apr 22, 2020 5:46 am
by ridenby
HillBilt wrote: ↑Tue Apr 21, 2020 12:37 pm
All CUCV 1984-87 are 6.2L ,TH400, 208or 205 , Blazers/M1009 have 10 bolt rears, Pickups/M1008,1028,1031 have 60/14bff
Posted: Wed Apr 22, 2020 11:11 am
by ridenby
The ORD crossmember/motor mounts
Replaced the inner spindle bearing with delrin .
PSC pump, Hydroboost
Posted: Wed Apr 22, 2020 11:31 am
by ridenby
Posted: Wed Apr 22, 2020 3:11 pm
Do those derlin spindle bearings hold up well for regular use, or are they just better for people that run into a lot of water and mud?
Posted: Wed Apr 22, 2020 6:04 pm
by Provience
ridenby wrote: ↑Wed Apr 22, 2020 5:38 am
awesome
awesome, thanks
Posted: Wed Apr 22, 2020 6:07 pm
Actually most dealerships I’ve worked at are required to have a case spreader as part of their shop inventory but due too the chance of cracking or springing the housing it’s generally off limits for the most part
