Durkota
Re: Durkota
I think they will be ok should have lots of clearance to the tire i can rotate it upright if needed but its not ideal for the line orientation. Il mock it up and see if i like it.
Re: Durkota
Chopped the frame for tire clearance just going to run 2.5" square tube to the bumper. Have to run a pusher fan set up because it wont clear the spouts. Probably do wiring and assemble the front clip this week.
Re: Durkota
A little bojank, but what if you slice the fan shroud apart so each fan is separate and mount them offset onto an aluminum shroud? Pushers blow...or just trim the shroud to fit the spouts through?
Re: Durkota
:poke: Or just go back to your original idea if getting me to move the spouts... :poke: :poke: :flipoff:
Re: Durkota
Im really skeptical that moving the spouts will give me enough room. Im not a "fan" of pushers either it just seems like the best solution. I would have to trim the shroud a bunch even moving both spouts we will see.
Re: Durkota
HMF wrote: Tue Feb 04, 2020 5:42 pm :poke: Or just go back to your original idea if getting me to move the spouts... :poke: :poke: :flipoff:
I'd say try this first... Pusher fans just "blow."
Re: Durkota
Hmf is working his magic on the rad meanwhile i dug my front clip out of the yard. Literally had to use an axe to get it out of the ice :homer:
Re: Durkota
is that ride height ? :eeks:
Re: Durkota
Dammm
Re: Durkota
Snowracer wrote: Wed Feb 05, 2020 3:31 pm is that ride height ? :eeks:
I wish thats on the rubber bumps so i have another inch of up travel and the wheel will come up a few inches when it articulates.
Re: Durkota
Sweet how much taller will it be at ride height?
Re: Durkota
Sexy lookin for a dodge hahaha
Jk i love small trucks and just enough height to get big ass tires under
Re: Durkota
Mr.gutsy wrote: Wed Feb 05, 2020 3:55 pm
Cut things off until you can make that ride height?
Re: Durkota
Scott Cee AKA 2drx4 wrote: Wed Feb 05, 2020 9:53 pm
Maybe when i go big block and cut the floor and trans tunnel out.... i dont have that much wiggle room as is
Re: Durkota
Damn Son!! :smokin: :smokin: Loving it :pimp:
