I may have a problem. Yet another unfinished turbo Sami?
- Been Liked: 19 times
Re: I may have a problem. Yet another unfinished turbo Sami?
Maybe they meant to write "2-4" instead of "24"
- Joe_the_ice_man
- Been Liked: 29 times
They'd fix the instructions though, wouldn't they?
- Joe_the_ice_man
So it runs, but smokes like a bastard. I believe I have a pressurized oil leak in the turbine "seal" if you can call it that. Apparently that is often caused by too much oil pressure, and I have a ton, so I'm gonna address that angle before just throwing a turbo at it.
Larger drain is the first step, I kinda assumed that 3/8 was too small, but it's what I had at the time. Bumping it up to 5/8 is the plan. Being a journal bearing turbo (a t25? from a 98 Saab if anyone is curious) people say you *shouldn't* need an oil feed restrictor, but I got one from the Amazon just in case, and I'll drill it out to the 1.8 or 2mm people say to run for journals.
Also started figuring out how to vent the valve cover to vacuum, cause I understand venting it to boost is less than ideal. I quickly whipped up a way to mount an air cleaner for the time being, I will move it and probably add a snorkel in the not too distant future.
- Has Liked: 158 times
You definitely need a bigger oil drain line than you had. Your new one might be okay, but honestly I'd go bigger if you can. Also try to make sure it's as straight as possible, or any bends are very gradual.
- Joe_the_ice_man
Most of the online kits were An10 fittings and -10 line, so I figured it would be safe, and I think I guessed right. No more smoky clouds everywhere, I briefly had some 5/8 clear tubing plumbed in there just to make sure oil wasnt backing up, and I had plenty of spare room for flow.
I think that bug is worked out, now to finish cleaning up lines, finish a fan shroud, and start messing with some tuning.
- Joe_the_ice_man
Did a little more research on the Innovate widebands, apparently 24" is where you want them because the controllers like frying sensors and no one knows why. Looked into this after my wideband was jumping all over and then throwing a EGT fault. Leaned out my mix some more and advanced the timing. It seems to be behaving again.
- Joe_the_ice_man
Havent had a chance to work on it lately, still gotta swap the rear third back to the Vitara one, finish the exhaust hangers and fix where a solder joint on the rad broke...but I been busy doing other things.
