Top Ramen
Re: Top Ramen
Messed around with the black box linkage and it there but you can see I had to trim the bracket to make it work. I will have to weld a piece in there as well as add some extra reinforcement.
Re: Top Ramen
Got the shifter linkage mocked up where it needs to be for the split case. Next is pull it apart install the black box seal and studs for final assembly and weld up the brackets for the shifters
Re: Top Ramen
I’m all over the place with this right now. I mounted the in tank pump with a questionable o ring setup cause I’m not using the recommended pump. I’m using what I have which is a 8.1 pump. Only to have a 8.1 come in on the hook for a pump replacement so I scored the oring/gasket
Re: Top Ramen
Tcase is bolted up for the last time hopefully. I’ve got the mount bracket pulled for final welding and paint. Tcase shifter is off to finalize brackets
Re: Top Ramen
nothing its what I had. there was a mix up and I was shipped two pumps for a uhaul job. I was told to hold onto it for the next one. Its been four years still on my shelf
Re: Top Ramen
Jay and brad had time yesterday to swing by and put my front together. Plenty room for the 8274 might even have room for a grill. I cut and sleeved the front bar work for the hydro boost
Should take a few hits I think
