Scott Cee AKA 2drx4 wrote: Fri Sep 18, 2020 10:53 am Compared with the old yellowed out headlights those LEDs are going to be as bright as the sun. :lmao:
Yeah they're pretty rowdy
pointsnorth wrote: Mon Sep 21, 2020 8:24 am you could polish those lenses with some super fine sandpaper and get them looking a little better
Maybe worth a shot but might just get some amazon front lights for it
looks pretty close to done, how much more you got left to do before shake down run ?
Snowracer wrote: Thu Sep 24, 2020 2:17 pm looks pretty close to done, how much more you got left to do before shake down run ?
-Rear Drive shaft-waiting on yoke from TMR
-Rear limit Straps
-Rear Bumper
-Wire compressor and locker switches
-Steering Ram Mount
-Trans service
-Plumb Trans cooler and install temp sensor
-Cut rear fenders and mod rear doors
-Cut front fenders
-Hood vents, and a bunch of misc stuff
so it will be ready for the thanksgiving baldy trip is what you are saying :flipoff:
Got a few things done on Saturday to make the Jeep mobile again. I need to move it out for a bit while I go over the snowcat before winter is in full swing.
Steering ram mount all done and painted. I am getting some slight contact on swaybar mount from the drag link, noticed some paint scrape. Clean it up with a grinder.
Trans got a service and plumbed oil cooler. I replaced the factory inline check valve with a strait through fitting
when is the shake down run
pointsnorth wrote:when is the shake down run
I dunno, May? Image
Dug the junk out the other weekend to get back on it
Started fender clearance on the rear. I’ll start with cutting it to the door, it should be enough but if not I’ll do the door clearance mod. It’s a lot more work than I’d like to do though Image
Found some previous mall curb damage behind the plastic.
Before
After
Cut the door apart. Don't waste your time. :poke:
I’d chop way more out of that rear wheel well
Scott Cee AKA 2drx4 wrote: Thu Mar 11, 2021 4:51 pm Cut the door apart. Don't waste your time. :poke:
Scoobienorth wrote: Thu Mar 11, 2021 5:51 pm I’d chop way more out of that rear wheel well
Ill have to do a travel test to confirm but the tire will clear from what I can see so why do more work than necessary?
The door mod is alot of work and will have to do something with the bottom door trim as it will need to be removed, either buff it up and paint match the scuff or go hillbilly and bed line the bottom black. This is going to be my wifes daily so Id rather not have it look like shit :lmao:
On a side note I finally tested the ARB twin compressor, its strait up gangster :pimp: way better than that single piston peasant shit, so when the jeep sucks on the trail at least Ill be able to fill everyone's tires up double time :homer:
HillBilt wrote: Fri Mar 12, 2021 10:35 am On a side note I finally tested the ARB twin compressor, its strait up gangster :pimp: way better than that single piston peasant shit, so when the jeep sucks on the trail at least Ill be able to fill everyone's tires up double time :homer:
Jeep guys out on the trail blowin everybody double time......
Johnny5 wrote: Fri Mar 12, 2021 6:40 pm [quote=HillBilt post_id=5524 time=<a href="tel:1615574150">1615574150</a> user_id=55]
[/quote]
:spit: :lmao: :lmao:
I ordered a drive flange for the rear output on the Tcase from Tom Woods so I can run a 1350 series CV. It’s strait beef.
Had to pull my Tcase out again as it was leaking between the trans, sealed it up and slapped back in.
