Page 21 of 31
Re: Picture of the day thread!
Posted: Mon Mar 15, 2021 10:21 pm
Wow for prison fab tats.
Posted: Wed Mar 17, 2021 6:06 am
by Johnny5
Too bad he cant grind that tat off
Posted: Thu Mar 25, 2021 6:30 pm
Customers complaint was a skipping sound
Posted: Sun Mar 28, 2021 11:50 pm
Posted: Mon Mar 29, 2021 5:43 am
by Muckin_Slusher
Creek opened up between us and the ice fishing shacks still on the lake. We plowed enough trees into the creek to drive across. Creek is 6+ feet deep and 25 feet wide. This is my wife and daughter on my SWT.
Posted: Thu Apr 01, 2021 8:14 pm
My boys are going to learn there is consequences to shooting their dad with nerf guns while he sleeps. Battery powered dual motor semi auto ten shot clip.
Posted: Sun Apr 25, 2021 8:20 am
Sucker for odd ball 4x4s. But a v8 solid axles and coils at all four corners for 500 bucks because no one around here knows anything about them
Posted: Sun Apr 25, 2021 12:23 pm
pointsnorth wrote: ↑Sun Apr 25, 2021 8:20 am
Gut the wiring and throw a Haltech or some other aftermarket EFI controller at it and it should actually be reliable. I've debated picking one up before to do that.
Posted: Sun Apr 25, 2021 5:41 pm
I love the Land Rover stuff. They work really well. Busy had one up north until he hit an elk and it developed electrical issues and Icbc wrote it off as soon as wiring issue and Land Rover were mentioned. I think ls, with gutted electrical and bigger diffs it would be awesome
Posted: Mon Apr 26, 2021 5:54 am
Scott Cee AKA 2drx4 wrote:pointsnorth wrote: ↑Sun Apr 25, 2021 8:20 am
Scoobienorth wrote:I love the Land Rover stuff. They work really well. Busy had one up north until he hit an elk and it developed electrical issues and Icbc wrote it off as soon as wiring issue and Land Rover were mentioned. I think ls, with gutted electrical and bigger diffs it would be awesome
Yeah wiring on these things is horrible. The last one I had at the shop was originally from Texas and was a nightmare. Body was mint but the underside showed it had most likely used to launch boats in the Gulf of Mexico its whole life.
It was towed from another shop who had diagnosed it as needing 3000 dollars in engine work including a pcm and crank sensor. I popped the hood cleaned and tightened the battery clamps so that it would even start. Put my scanner on it and got a ton of incorrect voltage codes. Tested the battery found it had a dead cell. Replaced the battery. Runs mint replaced the front wheel bearings and a brake line. Customer drove it away having paid nowhere near 3gs
This one a hauling company contacted me about they had picked it up in trade for a back haul knowing I’m the guy that would take it off their hands. Same deal as the last one every light was on and none of the fancy electric options worked. I drove it to the shop with it barely running. Cleaned the battery terminals and tightened the clamps. And then I was rallying it around the industrial park for twenty minutes.
Only thing left to do is see if I can adjust the shift linkage as it takes a bit of messing around to get the prndl indicator on the Centerconsole to light up on drive. It then relays the computer that then registers drive on the instrument cluster and then you have drive. other wise it just holds the trans in third. Land rovers are weird. They also do not have shift interlock so doing a drive neutral reverse at highway speed is easy. Seems it’s a common complaint if you look online at the pros and cons of buying one Of these
Posted: Mon Apr 26, 2021 6:03 am
These series twos were also the beginning of fords owner ship of land rover and ford was hoping to run this model for a few years and save some money before having to spend on a series three. One of fords cost saving feature was the Center diff lock wasn’t an option. Even though it is installed in the tcase there was no shifter for it. If I keep this thing around I might have to make a shifter for it.
Posted: Mon Apr 26, 2021 8:39 am
pointsnorth wrote: ↑Mon Apr 26, 2021 5:54 amThey also do not have shift interlock so doing a drive neutral reverse at highway speed is easy. Seems it’s a common complaint if you look online at the pros and cons of buying one Of these
That seems like a significant design flaw for such a new vehicle.
Posted: Mon Apr 26, 2021 10:51 am
oh yeah once your aware of it you definitely are careful about it. I guess it would be good if you were stuck and trying to rock it back and forth
Posted: Wed Apr 28, 2021 8:14 am
Posted: Fri Apr 30, 2021 7:20 am
After all the years of smashing knuckles while trying to remove transfer case bolts in tight situations I built me a tool to get at the wrench without smashing another knuckle. A quick shop poll of names and it is now called “the handi “ with “the reacharound “ a close second lol
