Making Chips
Making Chips
I figured there's a few of us that dabble with machining equipment to start a thread on some projects, tips and tricks for wannabes like me, and a good place for feedback from the pros
Re: Making Chips
A small piece I made a while ago for my TH400 cable shifter VS the old piece I was replacing
- Has Liked: 158 times
Re: Making Chips
I still haven't done much but bojang some stuff while figuring things out.
Tonight's bojang. Reaming a pitman arm to 1 ton GM DLE taper. I need to make some more fixturing stuff, or buy it, or buy a vise that can hold round things.
Re: Making Chips
It's not bojang if it works. You should see some of the setups I've come up with at work... if it works it worksScott Cee AKA 2drx4 wrote: ↑Sun Nov 03, 2019 9:13 pm I still haven't done much but bojang some stuff while figuring things out.
Tonight's bojang. Reaming a pitman arm to 1 ton GM DLE taper. I need to make some more fixturing stuff, or buy it, or buy a vise that can hold round things.![]()
Re: Making Chips
Is this some kind of shear pin hub coupler?
Re: Making Chips
Modified output shaft for a cyclone reduction gear unit this is the "small" one. The ones I have in the picture above are for the next size up
Re: Making Chips
Those cyclodial reduction units are nifty shit.
