Shop tj build
Has Liked: 71 times
Been Liked: 60 times
Re: Shop tj build
Ya. That’s pretty tall gears for a manual trans. I’d definitely go as deep as possible with the 6 speed.
Has Liked: 40 times
Re: Shop tj build
So this happened
Got call from a buddy that he had slid off the painted rock road and needed a winch. Image
Long story short the painted rock road goes thru a old burn and is littered with downed trees. Coming back after the recovery doing 20-30 kmh I went left around a tree fallen down and didn’t see the downed forty footer pointing straight at my drivers tire. I’m not sure if it jammed in the steering or what but next thing I knew I was two wheeling it on the passengers wheels and down over the right hand bank I went
Has Liked: 40 times
Re: Shop tj build
Unfortunately the lone boulder in the ditch is where I landed
Hard top has hole in it and is broken at the b pillar
In the last pic you can also see where the battery burned thru the fender
Has Liked: 40 times
Re: Shop tj build
I was super pissed about it and once we put it back on its wheels I rallied up on the road. And against my better judgement I decided to drive it home cause it didn’t look to have lost a ton of oil not realizing because it had drained into the air box so the motor is dicked
Has Liked: 140 times
Been Liked: 47 times
Re: Shop tj build
Well that sucks.
Time to tube it out and put a V8 in it?
Has Liked: 40 times
Re: Shop tj build
Already found a donor motor getting the car dropped off today
Has Liked: 71 times
Re: Shop tj build
I was going to ask about parts, just the inner vulture scooping things out. That’ll be a great motor for it though. Can’t wait to see it get fixed with that
Has Liked: 40 times
Re: Shop tj build
the 150 hp 2.4 tj motor is the same block as the srt4 just without the upgrades, oil squirters upgraded rods and pistons etc. this is a 05 which was 230hp stock but with the mods I have to do to make it fit in the tj it should make more then that. one documented build I found in a tj they put down a 13.05 on the quarter mile on it first pass with a dicked 904 three speed auto but also a slightly larger turbo on a pt cruiser 2.4 thats detuned to run 87 octane
Re: Shop tj build
That sounds like a cool upgrade then. Should be good for snow wheeling.
Has Liked: 40 times
Re: Shop tj build
so got in contact with guy in the us that did the same thing i want to do. he said using all the factory engine harness and dash harness with the srt cluster and it will work. he is 500plus hp which is nowhere how much i want.
ching chong mainfold 174
same same t3/4 turbo 209
cut and weld factory intake and boom shes good to go
probably not :lmao: :lmao: :lmao:
Re: Shop tj build
Unrealistic optimism is what makes these projects happen. Get to it.
Has Liked: 71 times
Re: Shop tj build
There’s enough hope to take a swing. It’ll be cool when it’s done
Has Liked: 40 times
Re: Shop tj build
slowly rounding up parts for this thing. fired the engine and it doesnt sound that bad. i got new mains and rod bearings and might just roll them in. got a hood and have dropped off cash with the body shop just need to round up a door in green and the cowl piece
Has Liked: 40 times
Re: Shop tj build
finally found a wrecker locally thats willing to at least try and work with me on supplying the body parts I need to get this thing fixed
Re: Shop tj build
It seems all the wreckers think everything is gold now.
