Dana 30 info
- Has Liked: 142 times
Re: Dana 30 info
They should bolt in with that later housing and wheel bearing setup. You might need to pull the ABS tone rings off the CVs, that would be the only potential issue, and that takes about 2 minutes with a gear puller.
- Has Liked: 71 times
- Been Liked: 61 times
Re: Dana 30 info
Man I’ve got a spare jk d30 housing and knew some guys that can weld that stuff. Makes me want to give it a try.
