Dana 30 info
OnlineScott Cee AKA 2drx4
Re: Dana 30 info
They should bolt in with that later housing and wheel bearing setup. You might need to pull the ABS tone rings off the CVs, that would be the only potential issue, and that takes about 2 minutes with a gear puller.
Re: Dana 30 info
Man I’ve got a spare jk d30 housing and knew some guys that can weld that stuff. Makes me want to give it a try.
