Giveaway Announcement!
Administrator
Site Admin
Been Liked: 1 time
Post by Administrator »
Win your choice of a Trasharoo Spare Tire Trash and Utility Bag, OR an ARB E-Z Tire Deflator, both $75 values, for absolutely free. Yes, whichever you like, for FREE!
This giveaway is open to ALL registered forum members who have made both an introduction post and at least one other post on the forum. Nothing other than that is required to enter, and this will automatically get your name in the drawing.
However, if you refer another member, who also makes the required introduction post plus one other post, not only will they be entered in the draw, but you will also be entered a second time. This member will have to mention that you referred them, or let a Moderator know.
This giveaway will run for one month, until Friday November 8th, and a winner will be announced shortly after.
(Limit of 5 entries per user. No "fake" accounts to get more entry chances.)
Trasharoo:
Trasharoo Spare Tire Trash bag in Digital Camo. Hauls, up to 50 lbs of weight. Fits tires from 29" to 40". Drain holes in the bottom of bag in case of unexpected leaks. Heavy duty stitching with beefy construction to last thousands of miles off road. X-strap design for added strength. UV buckle covers come with every bag. Standard 1 year warranty on buckles and general failures.
Carries up to 50lbs of weight
Made from high quality 900 denier canvas
Water resistant interior coating for bad weather
Drainage holes at bottom for unexpected leaks
Fits a standard 30 gallon trash bag for ease of dumping
ARB 505 E-Z Deflator
The unique, patented design of the E-Z deflator allows for removal of the valve core for rapid tire deflation, while also providing accurate tire reading via the simple movement of a sliding valve.
Corrosion resistant brass/stainless deflator tool
Quality bronze bourdon tube gauge design ensures accuracy is not affected by changes in temperature, humidity or altitude
Fully geared, solid brass precision movement
Easy to read dial with 1 pressure per square inch increments
Includes protective canvas pouch and instruction sheet
Has Liked: 40 times
Re: Giveaway Announcement!
remember to spread the word people.
Administrator
Site Admin
Been Liked: 1 time
Alright, that wraps up the contest.
I'll use a random number generator to pick a winner before the weekend is over.
Administrator
Site Admin
Been Liked: 1 time
Here's who got into the contest, and what their "number" is.
Scoobienorth - 1
HillBilt - 2
Snowracer - 3
Johnny5 - 4
Mr.gutsy - 5
Helidump - 6
YellowJacket - 7
HMF - 8
Shancerlelby - 9
Keegan - 10
BEEFY - 11
Master Yota - 12
BIGHOSS - 13
jeepmonkey - 14
XJ_Acker - 15
Bcheung - 16
Xj2001 - 17
Haywire Fab - 18
kimmer01 - 19
Lucas - 20
Administrator
Site Admin
Been Liked: 1 time
And the winner is BIGHOSS with his lucky number 13!
Congratulations BIGHOSS!
And thanks to everyone else who entered!
BIGHOSS
Post by BIGHOSS »
I'll take the ARB ez deflator :smokin:
Has Liked: 40 times
:cheers: good choice given your recent tire discussion :cheers:
