I got the other side done:
I did some more work to brace this mount. I don't think it will be an issue. All the welds on the mounts were double or triple passed. Lots of horrible welds because I was inverted.
- Mav.jpg (39.82 KiB) Viewed 3920 times
I also had to do some clamp bullshit for the fuel/brake lines:
I guess my driveshaft tried to eat them last time out. Not ideal. I might try to do something better here in the future. I also cut the defunct UCA mount off so the speedometer cable and everything else routes nicer.
I went back and added bracing to the mounts on the other side:
Again, bunch of shitty welds. I'm okay with it. It's bracing that wasn't there before. There is bracing on the other side of the mount too but I forgot to take a picture before I put the belly pan back on.
Then the rear main seal decided to go Exxon Valdez on me. Luckily I had one and the pan gasket set on hand, so I swapped it out last night.
Apparently AMC used a striated crank seal surface with a lip seal? I was very confused. I do not recall this on any of my other 4.0L Jeeps. Whatever, it didn't leak after I changed the seal.
Then I wheeled it today and eh. Not too impressed with the changes honestly. It performs no better at all than the bastardized short arm 3-link setup (I think Jeeple call this setup a mid arm??), but the link mounts take a huge beating on stuff that would probably miss them otherwise. Whatever, it works. I know I screwed up my axle placement a bit (I think I wrote the numbers down wrong and it's about 3/8" too far forward), but that can be adjusted back. I need to add about half an inch of bumpstop and half an inch of lift, and ditch the Fox remote reservoir shocks. The shocks are stud mount on the top and if anything pokes them they spin, then the reservoir gets eaten by the tire.
It's not a big enough issue to deal with right away, but I'll have to decide what I'm going to do about it. Once I look the thing over I'll see what else needs to be dealt with sooner or later.
