Top Ramen
Re: Samurai Buggy build-third times the charm right?
started with a bunch parts left over from a couple scrapped projects and a samurai truck cab
parts list ls 5.3, 4l60e, prototype northwest fab landcruiser black box combo fourteen bolt rear and landcruiser front axle
cab the day I brought it home.
Grabbed a piece of I beam from work and got busy cutting some 1.5x3x1/8 wall tube
After slinging some crossmember in there it was time for axles
Rear got a narrowed 14 bolt in the pics it was sitting on 60 series land cruiser springs. But they proved too long and it now sits on Toyota 4Runner springs
Front is a threelink with a panhard bar
This came in a tmr shipment the other day. Third one I’ve bought as I sold the last two. So I opened it up and installed this one
It’s a moulded piece as well as having the different diameter outlets
not really liking the clamps that came with it and will probably change them out for a silicone hose style clamp
That's one way to make sure you make progress, actually install the parts rather than selling them to customers.pointsnorth wrote: ↑Fri Oct 04, 2019 7:39 am
Is that prototype LC BlackBox something you got used? Or were they hoping you'd run it as part of their prototype testing?
I originally got it as part of their prototype testing and I know the output bearing and shaft have changed now in the production model. for all i know it will end up being a 3k paperwieght
Pulled these out of the box of goodies I’ve got stashed at home
Stripped them down and just installed the shock bodies to give me a perspective on where the upper shock mount will end up and how much uptravel i will have without putting the shocks thru the hood looks like I’m probably going to tip them back 12-15 degrees to give me more room in the front of the engine bay.
As you can see thinks are tight up front.
Trying to keep picking away at things
