ADHD build
- Has Liked: 144 times
- Been Liked: 49 times
- Been Liked: 85 times
Re: ADHD build
was to cheap to by exhaust elbows so bought a stick and wasted time and welding wire making a Y pipe
used the same muffler from the last truck but exhaust is quite a bit longer on this one
Re: ADHD build
started laying stuff our for wiring. autometer gauges and warning lights for battery and temp in the stock cluster
ignition coil, ignition module and fan pwm controller on the driver side fender
Re: ADHD build
been chipping away at this thing, mainly wiring and thats not super photo worthy. pretty much wired up other then some aux switches
got the important stuff wired up, lights
got the dash back together, no sold on the tach placement so might see if i can move that around
with the wiring done i started adding coolant and found the rad i had leaked, was able to pick up another one and it seems to be holding. dumped fuel in it and sure enough the fuel shut off valve and fuel cell fittings leaked, so took the valve out and got new fittings and that fixed the leaks. with the leaks taken care of i hit the starter switch and after a few fuel primes it fired right up and idled have some tuning to deal with but its getting close now
so made a list of what all needs to be done before wheeling this thing
Re: ADHD build
those are important as i got the doors on this weekend and stereo hooked up so have tunes but nothing to hold the wobbly pops
Re: ADHD build
made a simple front bumper
feel like it needs some lights in the bumper to make it look less square
didnt have any lights that fit so have to find something, but added a fender/grille bar and called it good enough for now
need to time and tune the efi a bit then load recovery gear, tools and some spare parts in the truck. otherwise i think its ready for shake down run next weekend
Re: ADHD build
started laying out the trail gear last night. looks like a spare 44 will fit just fine, bolted an ammo can in for recovery gear and cooler mount
did round stock around the cooler to hold it in place then an old seat belt to keep it there but still easy to open
- Has Liked: 74 times
Re: ADHD build
Seems surprisingly well equipped. Almost like you're planning to need a spare and recovery gear.
Re: ADHD build
spent some time setting timing and playing with the efi getting the IAC set and that went well. while all that was happening my fan decided it didnt want to work, even bypassing the controller it wouldnt power up. block heater started to leak and so did the rear main got a frost plug to replace the block heater. going to try some 20w50 shit box oil and see if it slows the leak enough that i can get out this weekend to see what else is wrong with the truck before pulling it back apart
Re: ADHD build
started off swapping fans out, had a big dual fan set up that i made work. it hangs over the side tanks a bit and i had to cut the bottom corner to clear rad hose. it moves something like 4000cfm so thats a plus
wanted to test the new fan make sure it was working and no issues. fired up the truck and it ran for about a minute then just shut off. fired it back up and ran for 30 seconds then shut off, did this about 3 times then just would not start at all. so swapped my new ignition box that has maybe 10mins of run time on it for an old 1970s one and truck fired right up no problem
figured with the new fan working and having the old ignition box in and working i would drain the oil and swap in the shit box 20/50 to see if the rear main leak would slow down enough to wheel this weekend. as soon as i started to loosen the oil drain plug coolant started to come out. might just be an intake gasket but between that and the rear main ive decided to just pull the motor and put i back on the stand and do new seals and gaskets and probably bearings as well. will deal with the leaking block heater at that time and toss new head gaskets at it as well. maybe a cam if got the cash
