The FSU trail buggy build
- Been Liked: 85 times
Well its finally happening, buggy time
So the build plan is
TMR 2" DOM chassis
BBF 429 with fitech efi
C6 full manual
NV271 tcase
79 HP60 with 4.88, spool and 4340 shafts
10.25 with 4.88 welded
3"x14 race runner coil overs up front
2.5x14 race runner coil overs and 3x14 racer runner bypasses out back
39 BFGs or 44 cut boggers for tires
Pics as everyone likes pictures
buggy on a skid
TMR 2" DOM chassis
C6 full manual
NV271 tcase
buggy on a skid
Re: The FSU trail buggy build
have started to strip the truck and should have all the parts out over new years and hope to have the drivetrain in the chassis as well
and for shits and giggles i tossed the trucks hood and grill on the buggy and its a pretty close fit so might see if i can make it work down the road
- Has Liked: 74 times
the obs grill fits quite nice, the hood not so much so will deal with that way later in the build
Definitely have a long way to go, hopefully you can make some solid progress.
- Has Liked: 144 times
I’d like to see how that tcase works out in the chassis. I have one I was saving for mine
Makes me sad to see fordnando like that. But bbf buggy is going to be sick!
got the truck stripped and out of the shop and on the trailer ready for scrap
pulled the chassis off the table and put it on stands so we could get the drive train in it. tcase is pretty big so have put it as far back as i could and might have to make a small skid plate extenstion for the tcase as rear out put is past the sub frame
its clsoe but will be able to do a flat floor over the tcase and most of the trans
and i had to sit and stare at this for a little bit
damm there is more room in there then I thought with the bbf. tcase is kind of where I figure thing would be on my chassis
if i wasnt running the 271 i could have come back a bit more and probably down 1-1.5 of an inch and would have fit even better. but for what i have im pretty happy with how it fits, only real upside to the massive subframe in the TMR chassispointsnorth wrote: ↑Mon Jan 04, 2021 9:42 am damm there is more room in there then I thought with the bbf. tcase is kind of where I figure thing would be on my chassis
i see your aiming for a 118-120 wheel base. Are you planning adding too the rear frame any storage etc or too early in the build for that?
