The FSU trail buggy build
Re: The FSU trail buggy build
got the front shock mounts done and welde on the chassis
bump stops, will add a gusset to the frame. when i pull the diff back out ill brace the lower landing pad as right now its just tacked on
finished up the front bumper and farilead mount
havent touched this in a few weeks as been busy with other stuff
helping the GF out with her bobber project
been out camping
watched some racing
but did add some more chassis braces, vertical tube where the chassis has the miter joint
cross brace between the shocks
been out camping
watched some racing
Looks like you've got enough chassis bracing in the rear there... If that fails other things are going to be pretty dickered.
- Been Liked: 17 times
It's probably fine but I don't like that the bump stop isn't at a node.
the winch crossmember ties into the backside of the air bump mount. if it was an issue im sure we would have heard about it with other tmr chassisarse_sidewards wrote: ↑Mon Jun 14, 2021 3:42 am It's probably fine but I don't like that the bump stop isn't at a node.
in fact tmrs in house race car doesnt have the rear down tube that has been added here
like Pointsnorth said there is so much other bracing close by with the winch mount and vertical tube i added that i dont see it being an issue. if i wanted to go full over kill i could cut a plate fill in behind the bump can in the chassis but that does feel like a bit much right nowarse_sidewards wrote: ↑Mon Jun 14, 2021 3:42 am It's probably fine but I don't like that the bump stop isn't at a node.
HMF winch plate got burned in
got the front limiting straps done. forgot to cut the mounting blocks for my adjustable straps off the truck when i scrapped it. so got my ghetto on and made some
lower mount will be attached to axle tube and lower link mount
I would have just used a couple links of chain for the length adjustment.
id rather not have to listen to chains making noise all day on the trailarse_sidewards wrote: ↑Thu Jun 17, 2021 4:13 am I would have just used a couple links of chain for the length adjustment.
still haven't worked on this in a while but did need to move it in the shop so tossed the 44s on and put it at bump. belly height is 12" and roof is 72". seeing it like this has gotten me all pumped to get back to this so maybe start working on it again soon
looks badass on the cut boggers but I dont imagine its a good time riding in anything other than snow
- Been Liked: 6 times
Works awsome in the snow i bet, any plans for heat in this thing? Not like you ever go out on cold days or into the mountains or throw snow around with them tires or anything hahaha
yes i have a heater for it as well as i have heated seats. do plan on doing a windshield for and sides for winter wheeling as well
