Shop life hacks
Re: Shop life hacks
On a side note if your hose as even a slight leak or the smallest pin hole your going too know about hahaha
- Has Liked: 140 times
Re: Shop life hacks
I only have a hand grease gun. Result of not being allowed to use anything else at work.
Re: Shop life hacks
A little something I came up with to straighten steel fuel line relatively quickly
Re: Shop life hacks
I’ve got the Eastwood one for 3/16 and it works awesome I just can’t justify the 3/8 one as the shipping from Eastwood is brutal
Re: Shop life hacks
Fluid transfer using a Chaplin deck sprayer and some brass fittings. Along with my transmission adapter kit this is awesome
Re: Shop life hacks
it makes filling some of these newer transmissions where you fill them thru the drain plug a much simpler and cleaner job
