Suzuki rims
- Been Liked: 6 times
Suzuki rims
I know dodge and old ford 5 bolt rims fit in the sense of pattern but the hubs are always just too darn small.
Is there any other stock rims that would fit and give me more offset? Or am i doomed to buy new rims?
I found a decent set that a special someone can machine down the centers to fit but since ther hub centered is that an ok idea? I thought about using spacers but spacers dont seam to be hub centered from what i can find.
Guess what im asking is if anyone has found sucess in adapters or spacers?
Or perhaps grand vitara rims have more back spacing? The damn frame on a tracker is real wide fir what it is and i wont be able to turn far with 31s
Re: Suzuki rims
Old Jeep Rims fit too. I’ve got a set of 16’s with Michelin ltx on them you can have cheap
Re: Suzuki rims
They are aluminum and have very little offset though so bigger tires might not work.
Re: Suzuki rims
Stock suzuki rims won’t work on your second gen tracker due to your bigger front brakes. And they are only a seven wide rim
edit they will fit if you run a wheel spacer
Re: Suzuki rims
With an offset of +25 that may be worse than the stock ones i have right now i believe there +20
I thought judging by those pictures it would have more offset but with google search it seams i am wrong. Those would be perfect for me now tho if they had a bit more offset.
If i had to run spacers realistically i could just keep rockin the 15s. Do they sell spacers that are hub centered? Having a hard time finding any
Re: Suzuki rims
Those are sweet but look there for a real damn wide tire haha.pointsnorth wrote: ↑Sat Mar 14, 2020 5:03 am
I’ve got a set of these brand new at the shop
Re: Suzuki rims
15 inch rim?pointsnorth wrote: ↑Sat Mar 14, 2020 12:12 pm They are a ten wide rim
Re: Suzuki rims
15x10, 2.5” backspace for those rims. I think.Johnny5 wrote: ↑Sat Mar 14, 2020 12:34 pm15 inch rim?pointsnorth wrote: ↑Sat Mar 14, 2020 12:12 pm They are a ten wide rim
Re: Suzuki rims
I’ve been trying to talk brian into those for the Mitsubishi jeep. If he Won’t go taller maybe wider
Re: Suzuki rims
A little before and after since I picked up some rims and tires.
I got some muddies that will go on that are a little bigger but these are perfect for testing fit and clearance and plainly to see how tracker is haha i bought, brought home and havent really drove it at all.
These pics are on the back because fronts gonna need a little material removed from brakes to fit rims but ill make her work
Re: Suzuki rims
Those definitely filled the wheel wells up. Look good though. Glad to see them being used. Be better with mt’s on ‘em
Re: Suzuki rims
Ya they look way better than the honda civic sized tires that were on there haha
Just the brakes rub here a little. Nothing a grinder cant take care of hahaha
